f350 pads and rotors
I have the 350 deisel and need pads and rotors on front. I pull a 6 ton trailer about 1/2 time. What pads and rotors would anyone suggest?
Ron |
An alternative POV. If the pads are new you can use them to help smooth out the surface on the rotors. Conversely using used pads will wear rotors unevenly.Not a huge deal but its usually best to keep the rotors smooth and with parallel sides.JJ _______________________________________Website I designed for pay day company.
Buy the ceramic pads, they are more expensive but better than metal. Metal leaves alot of dust. Ceramic absorbs more heat, and wont warp the rotors so quick.
| All times are GMT -5. The time now is 10:34 AM. |
