Ford f-250 super duty 4x4 front hub bearings
i replaced the whole wheel hubs about two years ago and six months ago i got front wheel bearing noise again. i dont want to replace the whole hub assembly's again because that is expensive and the hub assembly's are still good, its just the bearings. so what i am looking for is where can i get the bearings and what bearings are needed?
Many bearings have a product number or part number inscribed into the side of them.
Many times here we can give this bearing number to Canadian Bearing and they can cross reference it with their supplier and just sell me the bear instead of the hole hub. The next challenge is getting that bad bearing out and pressing the new one in without hurting it. |
Napa also has all of those bearings, but as Glenn said, the trick is getting the old ones out, and the new ones in without scratching or damaging anything.
well the problem is getting the bearings. I have take an old pair apart before without hurting anything. Thank you for the advice on where to go. ill get back to you guys when i get every thing done.
Good deal.
| All times are GMT -5. The time now is 09:01 AM. |
