HELP! F350 Brake Pedal going to floor
I have Replaced everything from the master cylinder to the wheel cylinders. When you plug the rear lines at the master cylinder it still goes to the floor have bled, flushed, everything. new calipers new booster. On the 5th master cylinder thinking it was a bad master cylinder.
HAve googled and cannot find anything please help!!! Thanks, Ben |
RE: HELP! F350 Brake Pedal going to floor
man,i dunno...sure sounds like air...how many lines to the master?
2 one to front splits and goes to the calipers and one to rear goes through RABS unit to rear axle splits and goes to the wheel cylinders....
thats what i was thinking was abs...they can be a real bear to get air out of...but yours is not holding with that blocked off??
usually theres another type of bleeder on the abs unit itself.
| All times are GMT -5. The time now is 04:30 AM. |
