How to identify brake failure
How to identify brake failure?
Identifying minor issues with your car’s brakes is crucial to avoid any dangerous situations like brake failure. The earlier you identify the problem, the easier it is to fix. Remember that a braking system has many moving parts such as rotor, disc, calliper, etc. You may have to keep an eye on such components.
Refer to the below points to understand how to identify issues with brakes.
Of course, if you have any questions, you can visit our website www.obd2.ltd.
- Screeching/grinding noises: It is a common sign that the brake pads are worn out and need a replacement. Ignoring brake pads could lead to a hefty repair bill as it may cause damage to other components as well.
- Shaking brake pedal/steering wheel: If your brake pedal or the steering wheel is shaking/rumbling, it may be due to some issue with the rotors. So, head to the service centre to get it checked whenever you feel that the pedal or steering wheel is shaking.
- Burning smell from brakes: It may be a sign of multiple issues with the braking system. Generally, it indicates unwanted friction within the components.
- Brake malfunction light: There are several warning lights on your dashboard, and the brake warning light is one of them. Whenever the brake warning light is on, never ignore it and take your car for a brake checkup.
- Brake fading: It is nothing but the loss of stopping power when you pump the brake pedal. It is caused due to overheating and can also lead to a complete brake failure.
- Brake fluid leakage: A slow leak in the brake fluid system can lead to brake failure. So, always pay attention to such leakages. Typically, you can find the fluid on tyres if there is any leak.
To identify brake failure, first check if the brake pedal feels soft or goes all the way to the floor. Listen for any unusual noises when you press the brake pedal. Also, notice if the vehicle pulls to one side when you brake. Look for warning lights on the dashboard that might signal a problem. If the brakes don’t seem to respond correctly or you see fluid leaks, it’s important to get them checked by a mechanic right away.
dave1125
Feb 24, 2020 04:21 PM
