How to Solve Ford VCM2 Module Programming & Configuration Timed Out Error
This article comes with an eastern European customer who bought Ford VCM 2 Diagnostic Tool that have this Module Programming & Configuration Timed Out Error.
Firstly, let’s check what he is saying:
Hi, Enclosed are a set of 7 pics, and Ill start with explaining what it is that I need to do… The Original PCM is no longer available to us and so a manual programming of the PCM MUST be COMPLETED… Keys must also be set for truck to operate… All Input values are known and ready to be uploaded to the PCM… The Exact process of programming may or may not be correct So Correct any Flaud Step that maybe the reason that this is not working correctly
IDS
The VCM2 is Found and Connected and Handshaking is establishe and Varrified by Acknowledgment through IDS Software… Within the IDS GUI, after the establishing and the successful connection with IDS, and Downloading the PCM’s Internal saved data… Next Selecting the “Toolbox Icon” (Left side top 3rd Icon) I select “Manual Programming” and hit the “Check”, After a couple seconds an Error occurs:
Selection NOT AVAILABLE, module programming
and configuration timed out due to out of date
IDS scan tool software. Please update the IDS
scan tool software to the latest level and retry.
(See provided pic for actual error)
What his attempts to solve:
I did attempt to download and install the Genuine Ford Update at www.motorsportservice.com but update Fails with “Wrong Version Found” This Update will update Ver 123.01 to 123.05 only (there is a Pic included on the desktop of the update) This Ver is 115.01
What I need to know is Can this IDS UPDATE, or Is there a work-a-round or method of programming a PCM With this Hardware/Software Comb as it sits out of the box…
Please Advise… Thank You in Advanced, your help is much needed and appreciated
Check provided pics to find actual error:
What suggestions given by our tech engineers:
This error occurred because the software used here is not the latest version. So customers can try if they can get access to the original IDS 123 software with license. All problems are gonna be solved! The functions can be realized easily through online coding. Any further problems, contact us directly.
IDS
shop2011
Sep 8, 2011 12:40 PM
