i have a 95 f350, whats the biggest tires i can fit?
i have a 95 f350 stock, no lift. it has 33 12.50 16.5 on it, they do not rub or anything. could i fit 35"s or 36"s with the same width with out rubbing? and if not, whats the smallest lift?
RE: i have a 95 f350, whats the biggest tires i can fit?
I have 35" BFG AT T/As on my '94. They clear front bumber,just barely,no lift..Some that see it think it must have a lift..tall enough..
I guess you ll be able to fit the 35"s in there and still have some clearance with a very small room for putting bigger ones. I guess you should stick to the 35"s and it should even give a substantial lift.....
