-   -   Just bought an 08' F-350 (https://www.truckforums.com/forum/ford-heavy-duty-101/just-bought-08-f-350-a-20458/)
mattymax Sep 25, 2014 09:27 PM
Just picked up an 08' F350 REG cab, 8' bed. gas 5.4ltr. Will be used for my landscaping company and primary plowing truck.
Just a few questions.
What weight oil you guys using ? How much does it hold ?
I would like to change the oil in both Differentials and the Transfer case . Any one have the print out for viscosity and capacity of all three ? Also going to bring it somewhere to have the trans fluid changed. What Viscosity ?
Also it has power locks but came with no fobs. Will it be compatibly if I purchase a fob for it ?
Thanks
Matt
In2Trux Sep 30, 2014 11:00 PM
Hope this answers any questions you may have about your new rig
2008 Ford Super Duty F250 F350 Specifications
http://www.fordf150.net/2008/images/superdutysmall.jpgSee also:
Ford Motor Company Press Release
Technical Specifications
F250/350/450 Powertrain/Chassis
POWERTRAIN
5.4L 3V Triton V-8
Engine Type
V-8, iron block, aluminum heads
Bore/Stroke
3.55 x 4.16 in
Displacement
330 cu in, 5400 cc
Compression Ratio
9.8:1
Fuel Injection
Sequential multi-port electronic
Valvetrain
SOHC, 3 valves per cylinder, variable cam timing
Power
300 hp @ 5,000 rpm
Torque
365 lb-ft @ 3,750 rpm
Oil Capacity
7 qt
Coolant Capacity
26.4 qt
Transmission Type
6-speed manual overdrive (all)
Gear Ratios
I
5.79:1
II
3.30:1
III
2.10:1
IV
1.30:1
V
1.00:1
VI
0.72:1
Available axle ratios
3.73:1, 4.10:1, 4.30:1 (F-250/350)
SUSPENSION
Front
4x2
Independent twin I-beam (Narrow Front Track) with coil springs, shock absorbers, stabilizer bar (F-250/350)
4x4
Twin coil mono beam (Narrow Front Track), shock absorbers, stabilizer bar (F-250/350)
Rear
4x2
Stabilizer bar with non independent live axle with leaf springs, staggered shock absorbers; stabilizer bar on DRW models, camper package and stabilizer bar package on SRW
4x4
BRAKES
Front
13.66-inch disc
Rear
13.39-inch disc
Assist type
Vacuum (F-250/F-350 single-rear-wheel gas engines) / hydro-boost (F-250/F-350 single-rear-wheel diesel engine, F-350 dual-rear-wheel), ABS
WHEELS AND TIRES
Base wheel and tire
17-inch steel on F-350 dual-rear-wheel; 17 & 18-inch steel on F-250/350 single-rear-wheel, 19.5-inch. on F-450
Largest tires available
20-inch aluminum wheel, LT275/65R20E
F250/ Dimensions and Capacities
Regular Cab
SuperCab
Crew Cab
8-ft
6.75-ft
4x2
4x4
Wheelbase
137.0
Overall length
227.0
Overall width
79.9
Cargo box length @ Floor
98.0
Cargo Width between wheelhouse
50.9
Fuel capacity (gal)
30.5 gallons with 141.8, 156.2 wheelbase, 38.0 gallons with 137, 158 and 172.4 wheelbase
