Please help
I have put a leveling kit on the front of my f250. After that I decided I wanted the rear to sit higher so I got 4" blocks. The blocks I got are longer than what was on there. Meaning there is more block touching the spring but they hang over the mounts. Is this ok or did I order the wrong blocks?
I'm not quite clear on what the issue is without being able to see it. But I can safety say, If your not comfortable driving your truck that way? It is probably wrong.
If i understand what you are saying correctly, it should be fine.
My son has a funny saying. "IT'S PROBABLY FINE"
Bon fire with the family in the back yard. Can't find 3 yr old granddaughter. Son says "SHE'S PROBABLY FINE" Tire has a slow air leak. Have to drive 100 km to get home. Is it safe. Son: "IT'LL PROBABLY BE FINE" You remember those times when sh!t happens and you think back, I wish I did it differently. Here is your opportunity to do it differently. If your not comfortable with it? change it |
I had hockey pucks stacked up and slid under the springs in one of my trucks. Worked great.
Lol :d
