rough engine
I have replaced plugs, leads, coil, distributor chasing a severely missing engine problem. Seems to be fuel-related but I have purchased a pressure test gauge and followed shop manual instructions and all the readings are normal and steady. Sometimes engine will sit and idle normally for a minute or two then suddenly act like it is going to die for 10 seconds then revive only to repeat the process. When driving the thing just misses badly and erratically. Any suggestions gratefully received
Have you narrowed it down to one cylinder and have you checked the injectors? My guess is that if the truck runs good while it is in neutral when it is using the least gas is that it may be a clogged injector and would advise that you try some fuel injector cleaner.
eaa1964
10
Sep 21, 2010 06:10 PM
z50kidd
Oct 11, 2009 12:53 AM
mikeybrow
Apr 8, 2008 04:32 AM
eaa1964
May 21, 2006 03:19 PM
