-   Ford Ranger/ Mazda B-Series (https://www.truckforums.com/forum/ford-ranger-mazda-b-series-19/)
-   -   truck died (https://www.truckforums.com/forum/ford-ranger-mazda-b-series-19/truck-died-16358/)
dino/dog Apr 13, 2011 09:29 PM
truck died
TRUCK JUST DIED DRIVING DOWN THE ROAD GAVE NO WARNING AT ALL JUST DIED GETTING GAS HAS SPARK ITS A 1996 MAZDA 2WD MANUAL PICKUP COULD IT BE THE CAMSHAFT POSITION SENSOR 4 CYL WITH 8 PLUGS ELECTRONIC DISTRIBUTORLESS ANY HELP WOULD BE GREAT THANKS:confused:
In2Trux Apr 13, 2011 10:20 PM
RIP 96 Mazda you will be missed
Sure it could be a CS posi sensor or it could be a number of other things.
If it was SUDDEN and no warning... it must have been an electrical issue.
Do you still have other electrical?
Will it still turn over (but not fire)
dino/dog Apr 14, 2011 06:12 PM
turns over good no other elec problems that I can tell .2.3L 4 cyl was running real good before it died just turns over no pop back fire .
Silverick Apr 14, 2011 09:09 PM
Have you checked for fuel pressure? Maybe the fuel pump went out?
dino/dog Apr 15, 2011 05:15 AM
getting fuel shot it with starting fluid still didnt start
In2Trux Apr 15, 2011 07:04 AM
Well if it's getting good spark and fuel theoretically it should run. So it maybe the camshaft positioning sensor or a timing issue.
Worf Apr 18, 2011 09:24 AM
remove the oil cap and have some one try starting the truck do you see the valve train moving? If not then your timing belt/chain broke.
DeuceBag Sep 1, 2011 11:58 PM
Could be a compression problem, stuck valve etc
