-   General Motors Tech (https://www.truckforums.com/forum/general-motors-tech-37/)
-   -   1994 c1500 4.3l v6 pickup's power steering pulley --- (https://www.truckforums.com/forum/general-motors-tech-37/1994-c1500-4-3l-v6-pickups-power-steering-pulley-5671/)
Clint Jan 1, 2008 02:50 PM
I have a 1994 Chevy C1500 V6 4.3L pick-up. I had new head gaskets put on after a water pump incident, and well, it won't budge. It's about an inch away from being in the correct spot.
Anyone know what I can do? Or what I need to do?
[IMG]local://upfiles/5881/8BE6B8A2C998447F937614CB1EBBF4C3.jpg[/IMG]
[IMG]local://upfiles/5881/1DBAC6C42BF341949DB1E39BEF5ADACF.jpg[/IMG]
[IMG]local://upfiles/5881/B46BE9BA2F744E5493B9024279280A05.jpg[/IMG]
stopspazinout Jan 1, 2008 04:01 PM
RE: 1994 c1500 4.3l v6 pickup's power steering pulley ---
does the pump need to go back towards the engine more?
Argon Jan 2, 2008 06:06 AM
the pulley needs to go on further?..do you have the correct tool?
Clint Jan 2, 2008 10:36 AM
well yeah, i mean, the pump is on completely and it's alligned perfctly on the block, haven't been using the correct tool...not exactly.. What should i be using?
stopspazinout Jan 2, 2008 09:56 PM
was the the pump removed from the accessory bracket or was the entire bracket removed?
Argon Jan 3, 2008 05:37 AM
the installer tool is a bolt that threads into the pump shaft,and has a big nut you turn with a wtrench to shove er on..a parts store should have 1 to rent
