2001 - chev - 2500hd - broken wire
2001 chev - 2500 hd - broken wire [/align][/align]
I noticed that my headlights were not working > started checking fuses everything good > service advisor said likely the main switch.. so I changed it.. i already had some of the dash off.. lights started working ... then I notcied that the lights would come on and off as I moved the tilt steering... started taking more apart.. then wnet back to garage.. they said it was a box by the tilt steering and have ordered one for me... then i noticed a broken wire .........yellow with a red strip ...... anyone know what this wire is for.. or have a wiring diagram subzero@mcsnet.ca I will send the pic to you ..... PLEASE HELP[/align] [IMG]local://upfiles/8345/B5BA462571624235BA395853EE400B60.jpg[/IMG] [IMG]local://upfiles/8345/BC585876D08E4396810D106A6E85EACF.jpg[/IMG] |
RE: 2001 - chev - 2500hd - broken wire
well glad to see Im not the only one with this problem I just fixed the same thing on my 97 suburban looks like the wire got hot in the pics check your grounds and connections....as far as fixing it well it came from one of the connectors.....unplug them and look it will be obvious where it came from when you get to that point let me know and i will help from there
Chris |
I changed the switch for the head lights & the box on the steering wheel that includes the signal lights, wipers , 4 way flasher, cruise.....
head lights still not work.... BUt the big problem is that the truck will start , run for about 2-3 seconds , the shuts down ... it does have the SECURITY light on... tried leave key in run position for 10 minutes the restarting , no help... tried spare key NO help ??? any HELP much appreciated.... |
I had the same security light problem with my tahoe. It is a passlock system problem. The starting and stopping of the engine is a passlock (security light) problem. Being that the security light is ON and not blinking indicates a module problem or an ignition key switch problem. Is it blinking? You need a modis or gmtech2 or 1 scan tool to diagnosis this problem. It probably is the resistor either in the passlock module or the resistor in the ignition switch...
Try turning the keyON but do not crank the engine. Let it stay like that for 12 minutes - exactly. Then turn key off for 7 seconds - exactly. Then try to start the engine.. |
Have you figured out where that broken wire leads to? I did the same thing pear69 suggested when my security light problem came up and it worked great for me.
___________________ WTB: tahoe aftermarket parts |
