-   General Motors Tech (https://www.truckforums.com/forum/general-motors-tech-37/)
-   -   305ci swap to 350ci (https://www.truckforums.com/forum/general-motors-tech-37/305ci-swap-350ci-11634/)
woggie3 Oct 5, 2009 07:01 PM
305ci swap to 350ci
I'm wanting to do this swap from the 305ci to a 350 crate motor. can someone tell me what i can use off of the 305 and what i will need to get new? i'm puting it into a 1985 k5 blazer.
Mr_Shamrock Oct 5, 2009 07:45 PM
Just about everything will swap over. All the accessories are the same. The 2 motors are identical on the exterior. You will probably want a different carb, but the 305 carb will work. Should be as simple as putting another 305 in it. Good Luck!
