-   General Motors Tech (https://www.truckforums.com/forum/general-motors-tech-37/)
-   -   350 engine (https://www.truckforums.com/forum/general-motors-tech-37/350-engine-20577/)
longdistance Jan 17, 2015 03:04 PM
350 engine
Hope someone can help me here. I bought a 1970 chevy c10 with a 350 engine. I want to ID the engine. I tried to get the number off of the block under the alternator. It looks as if someone has beat the numbers off. Whether deliberately???? Anyway. The only thing I a can get off of the pad looks like TMH or TMll. The only other I can get is 095 or 093. Not much to go on, but all I can get. Thanks for any help.
In2Trux Jan 17, 2015 08:58 PM
The block casting number on small block and big block Chevy V8 motors is located on a ledge found at the rear of the block, most often on the driver's side. This ledge is below the deck of the block and the ledge forms the mating surface between the block and the transmission bellhousing.
rodbuilder Feb 26, 2015 07:55 AM
What do you mean "ID it" If it's a 1/2 ton it's a 2 bolt main. What else is there toi know about it?
In2Trux Feb 26, 2015 09:03 AM
Identifying your engine with the engine code system provides a lot of valuable information.
And some not so valuable to the owner.
It will tell you the Month and Year the engine was built.
It will tell you the location (GM plant) the engine was built
It will tell you the projected hp and exact cubic displacement of that block
This is not real important info but depending how attached you are to your power plant or how attached you are to your truck... it kind of nice to know the history of that block
longdistance Mar 10, 2015 05:29 PM
350 engine
Thanks In2Trux for your info. It did help me. My engine according to the numbers was built/ used between 1969 and 1979. Again thanks for your help.
In2Trux Mar 12, 2015 10:27 PM
Glad to be of help.
Come on back some time and share some pix of your new 70 C10.
I'd love to hear what you have planned for it
