-   General Motors Tech (https://www.truckforums.com/forum/general-motors-tech-37/)
-   -   5.7 vortec cranks but no start (https://www.truckforums.com/forum/general-motors-tech-37/5-7-vortec-cranks-but-no-start-13957/)
silverado dude Jun 14, 2010 07:47 PM
engine quit on the freeway got it home, it cranks but wont start.tried new crankshaft sensor, coil, and distributor . i can hear fuel pump running in tank. pulled battery by mistake and lost any stored codes in computer. 98 silverado with 5.7L vortec. timing chain still intact. any help appreciated thanks :confused:
Mr_Shamrock Jun 15, 2010 06:56 AM
Check your fuel pressure. Just because the pump is running doesn't mean it's giving you the right pressure.
chevymansteve Jun 16, 2010 05:56 AM
98 Chevy
Your trucks OBD II system should hold all codes even if the battery is disconnected
silverado dude Jun 16, 2010 02:40 PM
its getting fuel, all the injectors are working and u can smell the gas, pulled the computer and hooked into my friends silverado with exact eng. and tranny and same thing happened to his truck, would'nt start. what about getting another computer would i have to get new or could i get a used one and would it have to be programmed for the engine and tranny?
Mr_Shamrock Jun 16, 2010 04:07 PM
Did you put his computer in yours to see if yours started? You need to look at the numbers on the computer and get the same one.
