87 silverado engine change
I replaced my 350 tbi with a carburated 305. what do I have to change on the fuel system to adapt it to the carburator?
RE: 87 silverado engine change
Wow..never seen anyone revert back to carb..
The pressure will be too high...13 psi will probably just blast past the needle valve. |
i would imagine gut the fuel pump. and cut down on the computer and youll be alright
im doin the same with my 1989 , but i have a 350 ... i was told just to put the mechanical pump on the motor and it will regulate it for you , but another friend told me that there would stillbe probleums with the intank pump ... so i guess youll either have to buy a regulator or remove the pump and just use the mechanical ...ill post my results after i get done with my swap this weekend ...
| All times are GMT -5. The time now is 04:34 AM. |
