-   General Motors Tech (https://www.truckforums.com/forum/general-motors-tech-37/)
-   -   92 Chevy K1500 Ticking Noise (https://www.truckforums.com/forum/general-motors-tech-37/92-chevy-k1500-ticking-noise-16165/)
blue92 Mar 20, 2011 11:13 PM
Hello all! I am having a problem with my truck. While it is in Park, Neautral, D, OD, it makes a ticking noise (while at idle, I cant hear it while its driving). It does not make the ticking noise in reverse! What can it be? Could it be an exhaust leak, something loose? I am confused. Like I said it does it in every gear position except reverse. That is while I am at a stop. (Like at a drive thru window) Any suggestions and help is appreciated! Thank You!
early93 Mar 27, 2011 08:44 PM
Sounds like a weak lifter tapping.
In2Trux Mar 27, 2011 09:42 PM
Could be an exhaust leak.
Use a LONG screwdriver, put the blade on the valve cover, over each cylinder. Then hold the handle to your ear while the truck is idling. You will quickly find a LOUD tapping LIFTER.
Or crawl under your truck (don't burn yourself) with your bare hand feel for an exhaust leak. I would start in the engine compartment with the exhaust manifolds and work my way back.
