'93 Z71 Tires with Lift Kit
I have a '93 1500 Z71 with a 3 inch body lift installed.
Any suggestions as to what wheel and tire combination would suit this truck well? (In regards to rim size, sidewall height, tread pattern etc.) I want to fill the wheel wells and lift the truck itself as high as possible without installing a suspension lift. I believe a 35 boasts a 4-6 inch lift over stock, is this correct and will this be the same if an aftermarket lift is already installed? Thanks for all the help. Rick |
