Door Hinge
Old 01-07-2007, 08:01 PM
knfenimore's Avatar
Default Door Hinge
I have an 86 c10 and the upper left door hinge broke. The door now only opens 1/2 way. I bought a new hinge and painted it, but I can not get to the inner bolts. I figured I would have to get the wiring off. The door has pwr locks and windows. There are blue ***** on top of each connector and say twist off or on. I twisted and the **** just came off. What is the trick to these connectors? I could not see how to get the rubber wire loom off between the door and frame. Does the rubber just pull away like a gromet? What is the best way to support the door while getting the old hing off and the new one on? Any tips or trick would be appreciated!
Thanks
Keith
Old 01-08-2007, 07:17 PM
knfenimore's Avatar
Default RE: Door Hinge
I got off the door and did not unwire it. I hung it from the rafter and removed the upper hinge and installed the new one. One problem, one bolt had to be accessed from under the dash trough a small hole. It was impossible not to drop the bolt and I lost a 9/16" socket down the A pillar. How do I get them out? I can not seem to find a access hole.
Thanks
Keith
Old 01-09-2007, 11:38 PM
magnet on a string.... or the parts store sells a 5lb pickup magnet on an extenable stick
Old 01-10-2007, 06:21 PM
knfenimore's Avatar
I tried a 24" magnetic flex tool and it was not long enough. I then cut out the magnet and attached it to my wire fish with aluminum duct tape. I fished it down the hole and never got a bite. The hole is only maybe 2" wide and you have to remove the lower left vent duct to get to it. It has a gromet with 2 wires, iguess for the door switch. I had to remove the guage bezel and then the duct. What a pain. I was hoping there was a hole some where, but I could find nothing under the truck or behind the brake release. I guess my snap-on socket and screw are gone forever unless some one has a new trick.
Thanks
Keith
rdowner22
12
08-04-2009 06:53 PM
mshaffer
09-26-2007 07:32 PM
coolman1987us
02-20-2006 10:51 PM
Bonefab
01-27-2006 12:24 AM
abtanner
06-08-2004 10:29 AM
Quick Reply: Door Hinge
