-   General Motors Tech (https://www.truckforums.com/forum/general-motors-tech-37/)
-   -   After starting in the morning the truck sometimes stops (https://www.truckforums.com/forum/general-motors-tech-37/after-starting-morning-truck-sometimes-stops-21098/)
eplegrand Apr 30, 2016 08:57 AM
I have a 6 year old truck that drove 160000 miles. I have it serviced on a normal schedule. It is a 3.2 liter diesel common rail truck. By the way, I live in Thailand so the model is different from the US. It is a Mitsubishi truck.
Once and a while, when I start it after maybe 5 to 10 seconds it stops. It is doing this only if I didn't drive it for let's say about 12 hours. So in the morning. Once it is running (and the engine is warm) all is fine.
Even though of course the engine has to warm up, the temperature here is over a hundred F.
Even after the last service it has still the same. Last service I changed oil and oil filter among other things.
Any idea what it can be?
NativeR1 May 5, 2016 09:50 AM
Even though the outside temperature is hot out the engine oil still has to warm up. Oil is thick before its warmed up. Once it warms up it can properly distribute through the engine. Try letting it warm up before you take off see if that helps.
