alt
Old 01-06-2010, 04:17 PM
24DUFF's Avatar
Default alt
I have a 1995 Jimmy charging problem 4.3 it was working fine and just stopped charging i think can boost it and will run till it kills the bat can any one tell me how to check the alt to see if it is charging. If it is working is there anything i should look at. ty Just had a look seems like the in dash voltmeter is reading 0?sry to all found my problem i guess my plow draws to much power burnt wire on back of fuse paneljust lucky to find it when checking fuse ty all
Old 04-12-2010, 07:52 PM
GMC1989's Avatar
You can take a meter and get a reading from the power wire to the housing of the alt. It should be over 14.60 or so. Another thing to is that you can try an amp clap with a meter or go to an auto store with the alt and the can tell you with there machine is the alt. is doing its job.
Old 04-13-2010, 01:28 AM
Worf's Avatar
Check out this thread
https://www.truckforums.com/forum/sh...ad.php?t=13465
above is a thread that will show you how to test your alt
mgcmn
03-26-2009 07:21 PM
ksoffroadtoy
07-12-2008 06:25 PM
jettinjoeyng
05-02-2008 01:20 AM
97 chevy
10-05-2007 06:35 PM
87 F350 banks
09-06-2007 07:35 PM
Quick Reply: alt
