Blowing heat when set on AC?
Old Sep 10, 2008 | 03:38 PM
Snake Boy's Avatar
Default Blowing heat when set on AC?
For no reason my AC blows heat. Sometimes as soon as I start it and sometimes just driving down the road after it's been working fine. I'm not talking the AC goes off I'm talking the heater comes on. Shut the truck off, not just the AC,for awhile and it's fine again. Any ideas?
'04 Z-71 5.3L
Old Sep 18, 2008 | 11:15 AM
americanautomoving's Avatar
Default RE: Blowing heat when set on AC?
Maybe you should check your AC pressure switch. I had one malfunction on my Jeep and it did something very similar. I don't think the heat is actually coming on, but its blowing hot air from the engine compartment into the truck. Check the switch (usually located on the compressor or near by) and refill your AC coolant. Good luck!
Old Sep 20, 2008 | 05:57 AM
Argon's Avatar
what year is it?..doies it blow hot out 1 side or both?
bonehunts
Dec 13, 2007 08:44 AM
majordad
Nov 4, 2007 12:37 AM
jcbst12
Oct 16, 2007 07:54 AM
Daddy Wags
Sep 9, 2007 10:15 AM
cajunwoodrick
Jun 13, 2007 09:06 AM
