A/C
i have a 1996 chevy k1500 and i changed out everything ac meaning comppressor drier and manifold hose. but i have no power to my control or blower motor. what can be the problem?
Checked fuses?
:Ddid you reconnect the plugs to the right places and or did you reconnect them at all and check your fuses
Fuses may well have blown if you turned the truck on when you had it all apart
I checked all my fuses none of them are blown, the relays under the hood are still good to. I even checked the relay behind the glove box and the resistor and everything is good.
| All times are GMT -5. The time now is 09:44 AM. |
