CHANGE A DUALLY TO SINGLE WHEEL!?!?
iS IT POSSIBLE TO CHANGE A CHEVY 87 DUALLY TO A SINGLE WHEELSET-UP? A LINK MIGHT POSSIBLY HELP ME OUT SO I CAN SEE IT DONE.. ALSO IF i WERE TO DO THIS WOULD THE TRUCK TAKE A LONG BED (8') OR A SHORT BED?(ARE ALL DUALLY'S LONG BED?- OR DOES IT DEPEND ON THE TRUCK) -THANKS
RE: CHANGE A DUALLY TO SINGLE WHEEL!?!?
If the front rotor has a hub adaptor on it just unbolt it it should have the same 8 lug pattern. the back should be a wheel swap. If you don't have ABS you might be careful of rear lock-up when empty or light loads due to less tire contact and a bigger brake.
