chevy tahoe lift please help!!!
ok, I have a 95 chevy tahoe 2 door 4x4 and is currently dropped like3 inches from normal height(for what i seen in most tahoes) i want to know if there's any way to could lift it back up with out buying a lift kit, im really confused cause the torsion bars are not adjusted, what else will make the tahoe be like that? is there drop spindles fo 4x4's? the lower control arm is straight compared to other arms that are tilted downwards a little, what could it be? please help me out
RE: chevy tahoe lift please help!!!
is your tahoe lower at all 4 corners or just the front? if its just in the front your springs could be bad or worn out but i do believe they make drop spindles for that 4x4.
your shocks should be air ride shocks. they automaticaly level and adjust if it is stock. you may have a hole in one or all of the lines or the systeem could have gone bad
