clutch problems
I hope someone can give me some advice. I have a 95 chevy pick up and the clutch engages as soon as you let it up off the floor there is no play whatsoever.
I may not be able to help but, if it's a hydraulic clutch system in that truck ( I don't remember) check and see if the fluid is low. Sometimes those things will leak down and cause that. Hopefully if I'm wrong someone will chime in and set us all straight.
want it do that if the preasure plate is getting bad i had a 77 ford that did that one time and turned out the spring in the preasure plate were weak
Originally Posted by bigblue81
(Post 46437)
