| hjfisk |
Oct 4, 2011 07:54 AM |
Fuel problem 98 chevy 1500
OK lets start at the beginning, I have a 98 K1500 had a problem last winter and replaced the fuel pump, turned out it was not the fuel pump and it was something else, never did really figure it out.Truck has run great for 8 months. Fast forward till this last saturday, Left house got fresh tank of fuel drove about 6 miles the truck starts bucking like it was either running out of fuel or had a tank of water. Truck dies have to get towed, check for water , no water in fuel, ck fuel pressure ah only 18 lbs fuel pump , change fuel pump [ under warranty] thank you, hook all up truck won't run ck fuel pressure 16lbs WTF, so I pull fuel pump again [ pumps are airtex] so I say they are no good and I bit the bullit and go find and buy a Delfi unit install it into the truck, same thing no fuel pressure 19lbs, WTF . so I pulled fuel filter installed new one, same started checking FP along fuel line, at filter , at pump, all the same. no blockage. So for piece of mind I got a battery and wired pump directly , pump came on pumped up 61lbs truck ran, ok pump good, must be wiring, checked all wires , did wire up date, checked resistance in wires all good, replaced fuel pump relay. It seems that what ever controls the pump for it to prime up to 61lbs is shutting off to soon. And because it holds right at 61lbs tells me that the FPR is working properly. I replaced the oil pressure switch and tried a known working CPU from another truck and it still does the same thing. I am lost with this thing. I even reset the security, with the 3 -11 min cycles. Any help would be appreciated. Thanks in advance. HJFisk :confused::confused::confused::confused:
