fuel pump
Need suggestions for a frame mounted fuel pump to replace my in tank pump.Stock pump has max free flow rate 60 gph,max pressure range 50 psi,min free flow rate 50 gph,min pressure range 40 psi.It's for a 1995 gmc yukon 4X4 with a 5.7 auto.Thank you for your time
walbro 255 pump is usually the best pump i've dealt with and has been used countless times as it is most likely the most popular
| All times are GMT -5. The time now is 07:59 AM. |
