GM Limited Slip
I just bought a '95 K1500 Suburban.
The original window sticker says it has a Limited Slip rear end. When I lift both wheels and rotate one the other side rotates in the opposite direction. Is this normal? Or does it need rebuilt, Or has someone possibly replaced the rear end w/ a non posi? It feels a little sloppy but makes no noises when rotating it by had or while driving. Other info; 3.73 gears,160k miles. Thanks:( |
RE: GM Limited Slip
Wheel turning in opposite direction is normal for limited slip. Drive the hell out of it!!1:D
RE: GM Limited Slip
Thanks for the reply, I'm more familiar w/ posi's.
