good or bad ?
is this fuse box good or bad it still works but i need to know if i should replace
https://www.truckforums.com/forum/me...lease-1408.jpg |
Looks fine to me. Why'd you pull the relay?
I can't see anything wrong with it. Why do you ask? What's wrong with it??
how can you not see thats its melted where i pulled relay top right prong area
I thought it looked a little suspect up there, but wasn't sure if it was just dirty. You might want to check the wire that goes to that slot. If you can find out the color of the wire and find where it comes out then just check the resistance from there to the prong.
yea im going to check that im not really good with wiring. but the fuel pump i think is what kicked it i bought a new switch and it hasnt kicked yet soo im thinking its fine but ive got a back up fuel pump just incase lol if thats the case
Still looks useable to me.... just need to find out why the relay is loading up so much..
well maybe you have a short in the wires somehwere that will case that problem
