-   General Motors Tech (https://www.truckforums.com/forum/general-motors-tech-37/)
-   -   have you install a lunch truck aluminum box before? (https://www.truckforums.com/forum/general-motors-tech-37/have-you-install-lunch-truck-aluminum-box-before-16607/)
lortech May 16, 2011 03:36 PM
I got a heads up on a 1988 gm Chevy truck with aluminum box mounted on it and want to know if you have installed these before? Is the bottom of the box two i-beams? how are they bolted to the frame?
Take a look at this 88 Chevy. I do not know its sub model. What would be the typical spread of its frame ie what is the distance center line to center line between both frames? I may buy this truck, and remove the box to install on my truck but do not know its frame spread.
