-   General Motors Tech (https://www.truckforums.com/forum/general-motors-tech-37/)
-   -   Hissing souns from brake pedal area (https://www.truckforums.com/forum/general-motors-tech-37/hissing-souns-brake-pedal-area-4533/)
ferg Sep 16, 2007 03:49 AM
I pulled an evasive braking manuever the other day and the next day I developed a hissing sound anytime the brake pedal is depressed. The sound will remain as long as the pedal is depressed. I'm looking at a booster failure right? The check valve wouldn't cause the hissing would it.
How ifficult is the booster replacement?
Thanks gents.
Jake
Argon Sep 16, 2007 07:05 AM
RE: Hissing souns from brake pedal area
yes,the booster is out.//..
i have no idea of your mechanical knowledge/tools,but its not that tuff....just tricky to get to the nuts under the dash....
what year truck is it?
ferg Sep 16, 2007 02:15 PM
Thanks Argon. I' referenced the Hanes and it looks fairly easy.
It's a 95 Z71, which brings me to my next question. How do I determine which brake system I have (JB-6 or JB-8)? Checkers only has a reanufactured JB-6 with no master cylinder.
Thanks
Jake
Argon Sep 16, 2007 07:28 PM
you have an RPO tag...should be inside your glove box..it has production codes...
