major help needed real quick like
hey fella's need some big time help in a big time hurry i finally sold my 85 ramcharger with the 6.7l cummins and took that money and got a chevy 1500 with a 350 putting over 486 to the wheels as of about 3 days ago i wouldn't stay in 4th (od) it would jump back and forth between 3rd and 4th figured it was a speed problem that didnt fix it got her back in the shop checked the trans level it was inbetween cold and hot (so about half a quart low) let her sit over night going out for the normal friday night of raceing makeing some money on the streets ( ya i know its not good to do but hey it works) on the way out every time it would go for second gear it would shift hard like the 700r4's do when u put a cam in them pulled over checked the level it was just a tuch low so added more smooth sailing till 4th still wouldnt grab night went fine never needed 4th on the way home it was acting up again with the picking 3 or 4 and hard shift into 2nd no work has been done to the transmission since i got it other then a shift kit filter plug or something more and yes it is the 460L-E
