-   General Motors Tech (https://www.truckforums.com/forum/general-motors-tech-37/)
-   -   Need help issues (https://www.truckforums.com/forum/general-motors-tech-37/need-help-issues-12734/)
jesselw87 Feb 3, 2010 06:23 AM
Need help issues
I am looking at buying this off or craigslist here is the add.
Truck is an 84 GMC 1/2 ton 4x4. 350 TBI motor. 700-R4 trans brand new rebuild(0 miles) out of a early 90's chevy truck. 208 transfer case. Brand New windshield. Aluminum wheels 33 inch tires. Front tires are 90% BF Goodrinch MT. Rears are 40% one has a slow leak. 4 inch lift. Shows spare in the photo does have all 4 matching wheels. Rear slider, newer style grill/head light assy. Now the down side. Fuel injection isnt working correctly. Not sure why. was told the trans needs a $30 painless harness to work on this older truck. Door panels are off. Ignition switch falls out.
if anyone has any input to help with any of the issues plz do so the main one i need help with is the trany thanks.
navinj Feb 11, 2010 07:28 PM
Danger!!!! Danger !!!! Danger !!!!! 2007-2010 gmc yukon denali, acceleration problems, delays of up to 5-10sec. !!!!!!! Can cause unexpected acceleration that catches the driver off gurard !!!!!! Dangerous situation !!!!! Reported to the nhtsa.... Be careful... High danger in merging and taking off.... Gmc refuses to take charge and fix this problem!!!!!!
