please help
tech says intake leaking,but i have had no problems with motor runs fine i replaced old thermostat that was sticking 2 weeks ago but have no others problems with motor would there have been obvius signs of a intake leak
RE: please help
So if you see no problems then why take the techs word for it? Try another shop.
RE: please help
are ya losing coolant?
RE: please help
yeah if your loosing coolant its probably burning it
RE: please help
if the intakes leaking your either loosing vacuum or burning coolant.
RE: please help
check your oil! the 350 in my 97 had a bad intake gasket right in the very front (drivers bank) and it started slow then began dumping massive amounts into the oil. or you could be burning it.
