running problems
Old Oct 29, 2007 | 11:01 AM
one44magnum's Avatar
Default running problems
i have a 89 z71 4x4 that starts and idles rough when cold,then idles to fast when it warms up...anybody got any ideas?
Old Oct 29, 2007 | 11:03 AM
Default RE: running problems
89z71 that starts and idles rough then idles to fast when it warms up..any ideas??
Old Nov 2, 2007 | 08:28 PM
vtech1's Avatar
Howdy, one44magnum. The throttle position sensor (tps) has gone bad from your description.
Old Nov 7, 2007 | 07:58 PM
04silverado's Avatar
89? tps wasnt introduced till 04 I believe, argon could shed more light on that. Check your basics first, fuel filter, air filter, spark plugs, wires, injectors?
Old Nov 8, 2007 | 05:49 AM
Argon's Avatar
TPS was introduced in 1987 on pickups...
as for the problem..it may be overfueling...maybe a map hose....any codes/?
Old Nov 8, 2007 | 06:55 PM
Thanks for that info, I heard someone else mention the tps before, and ive never seen a tps on a pre 04 truck.
Old Nov 9, 2007 | 05:15 AM
Argon's Avatar
any pcm controlled engine has a tps...throttle body pickups...even older caprices and stuff with carbs
mblanchard85
Jan 9, 2010 11:44 PM
grimreaper105
Jul 13, 2006 12:11 AM
chevyfreak36
Jun 8, 2006 02:40 AM
Polaris 500
Jan 25, 2006 01:48 AM
judykevans
Aug 15, 2005 06:51 PM
