-   General Motors Tech (https://www.truckforums.com/forum/general-motors-tech-37/)
-   -   Set Timing 1989 K2500 350 CID (https://www.truckforums.com/forum/general-motors-tech-37/set-timing-1989-k2500-350-cid-4438/)
Daddy Wags Sep 7, 2007 07:08 PM
I need to set the timing on the above vehicle. I need to disconnect the single wire (Tan w/black stripe) behind the plastic cover on the pass firewall. Where is that wire? Which plug is it? Is it in the middle, left, right?
Argon Sep 7, 2007 08:00 PM
RE: Set Timing 1989 K2500 350 CID
its on your right as you look at the firewall with the cover off...it may have a bit of tape around it...a 1-wire black connector
Daddy Wags Sep 9, 2007 10:15 AM
Found it. Thanks.
