Shift display on a 2K Tahoe
Hi, noobie here. I just picked up a 2,000 Tahoe. The ride is real clean. The gear indicator and odometer are electronic. The display has gone out three or four times. Where it goes then comes back I would assume this speaks to a short somewhere? Has anybody had the same experience?
Thanks. |
RE: Shift display on a 2K Tahoe
probably a faulty cluster...have seen a few
ORIGINAL: Argon probably a faulty cluster...have seen a few Thanks. |
yup.... all the gauges are built into one cluster. theyre all controlled electronically.
gm has been buying em on 03's and 04's...check with a dealer
Thanks guys. Sounds like my only option is to wait until it goes out for good then see what I can do to replace it.
