-   General Motors Tech (https://www.truckforums.com/forum/general-motors-tech-37/)
-   -   sputtering? (https://www.truckforums.com/forum/general-motors-tech-37/sputtering-806/)
nluoma Feb 14, 2006 02:52 PM
sputtering?
i have a 88 gmc 1500 i had a friend put plugs and wires on it because it was running really doggy. now its sputtering when u try to accelerate. he said he did the wires one at a time and he doesnt think he had them crossed any ideas im goin to compair it with a buddies truck later to make sure they are not crossed. what else should i look for or at?
ok all the wires were right. i changed fuel filter that didnt do it. than cap and rotar and that made it worse. so do u think timing?
Birddog Mar 11, 2007 05:22 PM
RE: sputtering?
carbureted? jets might be dirty , float may be stuck.
May also be a cracked vaccuum hose- those buggers can makeit run like that.
EGR might be crudded up too - take it off and clean it out.
Its a start , and so far a cheap fix that probably needs to be done anyway.
Argon Mar 11, 2007 08:50 PM
RE: sputtering?
It did NOT do this before?...if not,a wire is crossed,or he cracked a plug
