-   General Motors Tech (https://www.truckforums.com/forum/general-motors-tech-37/)
-   -   water temp (https://www.truckforums.com/forum/general-motors-tech-37/water-temp-4652/)
bigdirtychevy Sep 30, 2007 09:06 PM
water temp
hey guys im bryant. new to this site and im hoping yall can help me out. i have a 96 tahoe with a 5.7 v8. recently my truck has been acting weird when driving. my water temp will jump up to warning level, and then immediately drop back down to normal..then periodically it will do it again, then drop back down. i have no idea what i can do to fix this problem. a couple months ago i flushed my radiator, it has a new water pump, alternator and AC. i was told to replace the sensor thats right under the thermostat neck, so i did but didn't fix it..was also told it woudl do this if there was air in the system, so i ran it, then loosened the new temp sensor so that some fluid could come out and then ran it again and it still didn't fix it..any help would be much appreicated! thanks sooo much!!!!
Argon Oct 1, 2007 03:49 AM
RE: water temp
It certainly sounds like its low on coolant...If not,could be the gauge or sender...
I THINK..on that 96...you rep[laced the wrong sender...the one by the thermostat tells the ECM the temp...the gauge sender is at the LF head
