93 k2500 Trans to 92 k1500 SAS
Hello,
My 93 Suburban K2500 caught on fire during Hurricane Irma, but I was able to save the Jasper motor and trans. I have a 92 k1500 that has been Straight Axle Swapped. NP208 Tcase. 3/4 ton axles. I have already done the swap but need help getting the trannie wired up correctly. I have the old wiring harness and TCU. The 92 came with an auto but after SAS the people I got it from put an older manual in it. The NP208 seems to bolt to the 93 trannie just fine and puts the driveshaft on the correct side (passenger) The only thing I am having issues with is the plug. I know I will probably be changing some driveshaft lengths when it's all done but my main concern is just making sure it will shift right. Any tips would be highly appreciated. . |
