First Truck - What to get?
Hey. First time on the forum, but browsing it for the last while. I am looking into getting my first truck in a month or so, and would like to be well knowledge on my choice.
I am looking for a daily driver, but I will be towing a trailer(6x10, with 3 dirt bikes in it) and going on long trips through the summer. I live in Canada, so it is important this truck can handle snow, and weather of all kinds.
I am mainly looking into a Ford Ranger, Ford F-150, or Dodge Dakota. Of course, since it is my first truck..and first vehicle(that should give you an idea on my age..) I need it to be older. Perferrably 2000 and up. Crew cab? Would be nice, or even Ex-Cab.
So, theres my info. I am trying to get a take on which one would be best to get. I'm hoping to get a lot of different opinions..and not too many biased ones. Which truck would you recommend? I know the F-150 is the biggest of them all..but which is most reliable? Oh, and I prefer V6 right now.
Any thing you guys can tell me about these trucks to widen my knowledge would be excellent. Thanks!
Welcome to the forum.
For a first truck, I suggest a Ford.
A Ford F-150 from 2000 and up works well for daily use. It can tow a 6x10 trailer with dirt bikes. It handles winter roads with 4x4. Parts are easy to find in Canada.
A Ford Ranger also works. It costs less to buy. It can tow your trailer if set up right. Space is less than an F-150.
I would skip the Dakota. Many owners report problems. Parts can cost more.
A V6 F-150 or Ranger is fine for your needs. Crew cab or extended cab both work. Choose 4x4 for snow.
Check service records. Check rust on the frame and body. Test drive it.
My pick is the Ford F-150.
since you're in canada and towing three bikes through snow, go for the f-150 with the 4.2l v6 over the ranger or dakota. the larger frame gives you much better stability and braking for towing, and that specific v6 is a tank that's very easy to learn on for your first truck.
just make sure it’s a 4x4 for the winters and consider a breathable cover to avoid fading and cracking on the interior since older truck plastics get brittle in the sun and cold.
giggey
Sep 25, 2008 05:17 AM
