How to unlock a frozen engine
Step 1. Remove all spark plugs
Step 2. Fill the cylinders with Diesel fuelhttp://images.intellitxt.com/ast/adTypes/2_bing.gif put plugs back in Step 3. Let it sit for about 2 weeks. Step 4. Take out the plugs, using the crank pulley nut attempt to manually turn the engine over. If it dosnt move put the sparkplugs back in a try leaving it be for another week. Step 5. When you do get it moving freely turn it over by hand until you have most of the diesel out of the cylinders. Step 6. Install new spark plugs, change all the fluids and a new strong battery. Add a little fuel in the carb and see if it starts on its own. If the engine started then you are fine, but if it didnt start or even try then there is something else wrong with the engine. If the engine is running, you will notice it's may not be running real smooth, and is blowing a some blue smoke out the exhaust. This is normal, unless it keeps smoking after all the diesel has been burned out of the engine. |
that is very helpful
i could have used this about 2 years ago when i was rebuilding a briggs and straton hot air baloon fan that blows up the balloon this thing was old it had wood props and all but i jsut took the engine apart and forced the pistons out worked great after i bored it out and replaced everything |
well now you know for next time :-)
