Newbie questions
Total Newbie here... first post.
I'm going to buy a truck. I don't exactly what kind yet; I'd like to ask for input/suggestions/recommendations/etc. Just a couplerequirements... 1. Full size, V8. I do a lot of projects around the house, in the yard, car restoration, etc. I want a truck that, if I decide to buy a '69 Camaro, I can load it onto a flat bed trailer and tow it with the truck. AndI don't have to worry if the truck has enought "guts" to handle it. 2. Extended cab (not the full 4-door, but with the smaller opening door... at least one side). Like to have, but not requirements... 3. 4 Wheel Drive 4. Full-size bed (can fit a 4x8 plywood sheet in the bed with the tailgate closed). I'm not predisposed to Chevy, Ford, or Dodge. I'm thinking it will be somewhere around a 98 - 05 model year; I'd like to spend not more than $15,000. So... the questions... For each line (Chevy/Ford/Dodge), what's the first model year that's "ok"? In the range of model years that I mentioned, what's the best year? Anything special that I need to look for or ask about? Any particular body issues (like, are there certain years that are prone to rust)? I mentioned that I'd like to have 4WD, but is that a good idea (I live in Kansas where snow can be an issue occasionally)? GM guys: Is there any mechanical difference between Chevy and GMC? Are there any significant cosmetic differences? I know GM had some trouble with the 700R4 transmission in the 80s and into the 90s... did this ever get straightened out? What year is the first that's ok? What year is the best? Dodge guys:Is a Hemi worth it? Ford guys: Is the 5.4L engine worth it? To guys who have crossed over brands (well, really for everyone): Please give me your thoughts from a comparison basis (like, Fords are great, I'd never own a Chevy) (or vice versa). And I didn't mention Toyota or Nissan... it seems they tend to be a little more expensive than the American trucks. Should I consider them as well? I know this is a pretty big question; sorry for being a little vague. I've "casually" looked at trucks for years (obviously), but I'm just getting started looking seriously. So any and all input is great. Thanks. |
For Chevy in the years you listed, the Silverado 1500 is a good choice. After 1999 they improved the design and reliability. Watch for rust around the rocker panels and cab corners.
For Ford, the F-150 from 1999 to 2004 is common. The 5.4L engine can tow but check for timing chain and spark plug issues. Rust can show on frames in those years. For Dodge, the Ram 1500 from 2002 and newer has a stronger body. The Hemi has more power, but the regular V8 can still tow well. Look out for front end wear. Chevy and GMC are mostly the same. The difference is trim and style. The transmission issue was improved after the mid-90s. 4WD is useful if you get snow, but it adds cost and uses more fuel. If you want to tow and also use it in winter, it is worth it. Toyota and Nissan cost more but can last long. If you want lower cost parts and easier service, the American trucks are better in your price range. Also, check online auctions that have 360VIR Exterior Spin. It lets you see the truck from all angles before you bid. The benefit is you can spot damage, check details, and feel more confident without being there in person. |
| All times are GMT -5. The time now is 01:14 AM. |
