Power Inverter in tool box charging booster pack
Old Aug 1, 2017 | 12:44 PM
glensing3's Avatar
Default Power Inverter in tool box charging booster pack
I recently had a dead battery and decided I needed to invest in a booster pack. I foresee having a problem remembering to take out the pack to charge it every month or so, so what I want to do is install a power inverter in my toolbox. I was thinking running some heavy wire (maybe 2 or 4 gauge) back to my toolbox from the battery and install a relay switch close to the battery that will close the circuit when the key is turned on. I have wanted to do this in the past to use small things like drills and saws while working on the farm. Every time I turn on my truck, the inverter will be working just to have the pack topped off to prevent the monthly charging and I think it may work to keep the battery in better shape for the booster pack as the pack I bought has an automatic charger that claims you can keep it plugged in indefinitely. When I use the booster pack and drain the battery significantly, I anticipate plugging it in at the house to do a full charge. My question is this: is it dumb to convert your 12 volt dc from your car battery to 120v to keep a 12 volt booster pack pack charged just in case the car battery ever has a problem? ... Or should I just set an alarm on my phone? Thoughts?
Mox
Feb 15, 2011 01:56 PM
rowdy14
Apr 10, 2008 08:22 PM
smoke20
Mar 28, 2007 08:15 PM
Carson
Jan 7, 2007 12:28 AM
Carson
Dec 20, 2006 01:36 AM
