Rear drivers side widow
I have a 2004 Dodge Ram 1500 4 door . Having issues with drivers side rear window not going back up.. I have replaced window regulator and front door control panel still will not work. Window will go down using rear switch only but will not go back up using either front or rear switch. The window lock button also not working. I have power to the door because the door lock will work. If anyone has any suggestions or a idea on issue i will greatly appreciate it. Thanks in advance
Keith |
