-   GM How-To's and Tutorials (https://www.truckforums.com/forum/gm-how-tos-tutorials-84/)
-   -   DID YOU KNOW? Frames Crack. (https://www.truckforums.com/forum/gm-how-tos-tutorials-84/did-you-know-frames-crack-20327/)
In2Trux May 31, 2014 09:18 PM
DID YOU KNOW ?
Apparently the frame on a 73 - 87 4x4 has a weak area around the steering gear.
Cracks in the frame are common on the 4WD model due to high loads placed on the steering gear. This can occur from over sized tires or diff lockers Check your frames gang.
