Installing Load Resistors For LED Lights
A 6 Ohm, 50 Watt LED load resistors will work on any vehicle and can be connected across the turn signal bulbs or License Plate Lights to simulate the load of a regular filament bulb (2 Amp load). This will solve LED related turn signal lights or license plate light problems such as hyper flashing or stroking, no flashing or burnt out bulb indications. One LED resistor is required for each turn signal bulb or each license plate light bulb.
Connection Instructions Connect one wire to ground and the other wire to the turn/brake wire. You can use the T taps so you do not have to cut your car's wiring. One Load Resistor is required for each turn signal bulb. For more detail, check the diagrams in the attached video Note: LED Load Resistor will get HOT, therefore, please don't mount the LED load resistors on plastic. |
