-   Lincoln Blackwood (https://www.truckforums.com/forum/lincoln-blackwood-34/)
-   -   suspension mods for blackwood (https://www.truckforums.com/forum/lincoln-blackwood-34/suspension-mods-blackwood-5859/)
mcqueen Jan 16, 2008 06:43 PM
You can spend a few bucks on some performance shocks and simple brackets to completely change your Blackwood's height and look. You can also opt to ditch the stock springs and shocks altogether for a set of adjustable air bags. Or, if so inclined, you can go with something like a 15” body and suspension lift kit that requires an air-traffic controller to pull into your driveway.
Though some people install a suspension lift for aesthetic purpose, others purchase it for its principal purpose-- to lessen the jarring of the automobile that is caused by irregularities in the roads traveled.
There is an abundant online lift kit shop in the web or you may try at Amazon, Suspension Lift Kit.Net, Ebay, and other online sources. With just one click, you may readily purchase top of the line suspension lift kits of a particular brand and type.
