$200 Rebate on Superlift Suspension Upgrade Kit for GMC Sierra / Chevy Silverado
In order to excel in product design, Superlift has gathered one of the most experienced and skilled teams in the industry, one that makes use of cutting-edge computer modeling technologies and the latest innovations in production techniques. The company's bread and butter is a range of top-quality suspension lift and leveling kits designed for specific models of cars and trucks. The majority of the initial project specs are given to the Superlift team by the automakers to make sure the new kit is ready for the order once the new model of the vehicle hits the dealerships.
By using Superlift products, you can enhance your vehicle's appearance, comfort, and performance while also improving handling and control. You may currently purchase a Superlift lift kit and get a substantial rebate! Through March 31, 2023, get a $200 Visa Prepaid Card when you buy a Superlift Lift Kit that costs more than $1250. Act now, don't wait! Please complete the following PDF form to get your rebate.
Superliftฎ K1013 - 3" Standard Front and Rear Suspension Lift Kit
https://www.carid.com/superlift/3-st...mpn-k1013.html
Fits: 2020-2022 Chevy Silverado 2500/3500
2020-2022 GMC Sierra 2500/3500
Notes:
Due to the differences in manufacturing and dimensions in the Silverado vs Sierra, it is highly recommended that all tire and wheel combinations should be test fitted prior to installation
Due to GM larger Front brakes on the 2020, Check with Aftermarket wheel manufacturer for wheel compatibility on 2020 vehicles
Allows use of OEM Shocks
Specifications:
Without Shocks
Install Time: 2-3 Hours
Install Difficulty Level: 2 of 5
Max Tire Size: 35"x12.5"
Wheels and tires recommended parameters:
Tire Size 245/75 R17, Wheel Size Factory 17" with Stock Backspacing
Tire Size 275/70 R18, Wheel Size Factory 18" with Stock Backspacing
Tire Size 285/75 R18, Wheel Size Factory 18" with Stock Backspacing
Tire Size 275/65 R20, Wheel Size Factory 20" with Stock Backspacing
Tire Size 35x12.50 R20, Wheel Size 20"x9" with, 0mm to +20mm Offset
Features:
Differential Spacers maintain proper CV axle angles
Increased Ground Clearance
Retains OEM Caster and Camber alignment specifications
Can be returned to stock with no problems
CNC machines ball join sock and bushing eye ring for a precise fit
Designed using Original Equipment (OE) CAD data for accuracy
Compatible with factory stabilitracฎ and anti-skid control features (No Problems or irritating dash lights)
No excessive ball joint or steering components
Includes:
U-bolt Square Bend (3/4" x 3-1/8" x 12")
1.5" Rear Lift Blocks
Case Hardened Flange Nuts (3/4")
Torsion Bar Keys (DR and PA Side)
Shock Relocation Brackets (Rear, DR and PA Side)
Shock Spacer (Front Top, DR and PA Side)
Differential Spacer (Rear, DR and PA Side)
Upper Control Arm (PA Side)
Differential Spacer (Front, DR and PA Side)
Upper Control Arm (DR Side)
Hardware
You can browse the full Superlift suspension parts catalog here:
Need some tires? Here are some of the options you may like:
https://www.carid.com/cooper-tires/d...-17749573.html
https://www.carid.com/atturo-tires/t...723985487.html
https://www.carid.com/general-tires/...972065461.html
If you have any questions, give our sales team a call at 800.505.3274 (Toll-Free) or 1.609.642.4700 (International).
carid
Nov 2, 2018 07:28 AM
